RE: First IMAC model
I pretty much agree with you 3D Joy. If you can't fly the sequence with a 120-size Sukhoi you won't be able to do it with a 40% either.
I'm not totally in agreement with you on the cost difference between a 25% glow and 28% gasser. I built my 28% Laser for $1700. The Goldberg Sukhoi and YS 140 will be an easy $1250 to build. The much higher cost of glow fuel vs. gasoline will make up the differencebefore you know it!
I'm not trying to push Brian into larger gasoline powered models, I just want him to see the cost really isn't that far off from a 1/4-scale glow model. And I think the difference is worth it.
