RCU Forums - View Single Post - Epoxy or CA for framing?
Old 09-02-2004 | 11:34 PM
Daryl_y
Default RE: Epoxy or CA for framing?
I use thin ca on nearly everything if its a tight fit it is a Superior glue joint to thick or medium ca I only use epoxy for firewalls, landing gear blocks and wing bolt mounting plates. I use thick ca for tail feathers then I run thin ca down the seams after it is glued. If you put faring on your tail there is no reason why this is not strong enough. Remember it only has to be stronger than the wood
