RCU Forums - View Single Post - Split elevon setup problem
Old 09-03-2004 | 09:12 AM
tomcatman's Avatar
tomcatman
Default RE: Split elevon setup problem
Negative....the Y lead on your "AILERONS" is the problem. By matching those 2 servos together, they don't work "INDEPENDENTELY" and therefore, the radio can't work them separately so that one goes up and the other goes down. Yes, you CAN use a matchbox to reverse the throw on one of them, but then you cancel out many mixing features you can use on your computer radio. The aileron servos must be connected individually to different slots on your receiver. With my setup, slot 1 gets one aileron and slot 6 gets the other, thus controlling each independentely. From there, you can reverse any one as needed right from the transmitter. Hope this helps...let me know if you still need help.
