RE: Split elevon setup problem
The best way to sort your problem is to use 4 channels on your receiver then you can mix them how you want , ie the inboard can be used as elevator and the outer as ailerons, or you can mix them as elevons , this way you have some chance of getting back in one if a servo goes down.And also you can set up crow breaking
