Check this out. First pic i want to show you is that edge thats chewed up on yours. Mine is spotless. I am however glad you are wrong about that. Id be really pissed off to put aluminum cases in this, and see my case chewed up like that.
Next pic, an slightly different angle. You can see this diff case was not run long at all.
Heres a pic, where you can see the crack. This crack runs from front, near the pinion, to the back half.
Here is the crack from the inside.
Another from the inside.
I really wish i could just throw a diff case in here and run it a while. But im gonna be really annoyed if i put a plastic case in here and it breaks again. I sure wish Bill at Losi would see these.
