RCU Forums - View Single Post - Possible diff case problem?
Old 09-03-2004 | 09:29 PM
ThermalRD's Avatar
ThermalRD
Default RE: Possible diff case problem?
You could be right on the gear mesh. The gear mesh is very tight between ring and pinion. As far as over tightening those screws. Not gonna cause it. You would have to see how TINY these screws are that hold it together. Im sure at the mere thought of over tightening them, id have a stripped diff case. The cases are VERY thin. I might buy another tomorrow, and try my luck. Expect me to be a raving lunatic if i blow another front case. I really dont even wanna bother with the truck until my aluminums come in.
ORIGINAL: i8tweety
Thermal,
One thing that could have caused the diff case to crack like that is a combination of minimalist design, an over-tightened screw, and poor gear mesh (causing backlash and hard hitting outward forces).
