RCU Forums - View Single Post - What's a muffler?
Old 09-04-2004 | 12:27 AM
kokamo's Avatar
kokamo
Default RE: What's a muffler?
If I were to buy the TT 46 pro, does it come with it?
I think a TT .46 engine comes with a muffler, not sure though.
What's actually a muffler?
A muffler IS what makes the engine more quiet and in most cases, makes the engine work more efficiently.
So is it necessary to have a muffler?
Most club Fields require a muffler to keep the noise down to a certain level. Again, some engines may not run very well or not at all without a muffler.
I always hear you guys said "to take the baffle out of the muffler" What does it actually means?
Sometimes the manufacture of the engine will install a "baffle" inside the muffler to create back-pressure to either help the engine produce power/ and or pressure for a fuel system. Alot of glow engines require some sort of air pressure to push into the tank, in turn forces fuel into the carburetor of an engine. If you remove the baffle out of an engine, you may get more power, you may get less power, or you may not get enough back-pressure to operate your fuel system. Then the engine won't run at all. YOU WILL GET A LOUDER EXHAUST SYSTEM IF YOU REMOVE THE BAFFLE.
Hope this answers some of your questions.
LATER!!!
Joe
