RE: Glow Plugs
A 4-stroke plug runs much hotter than a 2-stroke plug. A 4-stroke plug needs to retain the heat of each combustion cycle longer than in a 2-stroke engine because it only fires every other stroke. They do work good in some larger 2-strokes as mentioned but you have to make sure it clears the piston. I would not use it in a small 2-stroke.
