Little play in elevator can cause flutter?
Any gap or loose feeling in the controls will cause flutter. If you are using CA hinges and you have up and down movement in the surface and a gap you will get a flutter. simple fix is to mono-coat or tape the gaps to prevent a air flow which causes flutter or to install pinned hinges when putting them together. I use pinned and make sure I have NO gap between the surfaces.
