Little play in elevator can cause flutter?
You have to make the tape into a hinge also. Open the elev as wide as it will go, insert the tape to the bottom of the slot, it will look like a V when inserted and the adhesive takes hold the tape is now a sealer and part of the hinges. Now you have no air flow between the 2 pieces so no flutter.
