ORIGINAL: fantomas
you need a different on/off switch.. the one the losi has the small red plug.. you need to get a jr on/off switch with a standard black plug...
well ok.. there aren't any with the red plug? Everything I saw at the lhs had the black plug. It seems odd that you'd have to rewire just to use the flat pack.
I read the other threads on the same subject and it seems everyone is either making custom setups or using the 7.2v
