ORIGINAL: Atlantaeflyer
The Salt makes the water more conductive. You will see tiny nitrogen bubbles coming out of the connector as the cell energy is released. Soak it overnight (if there is a good amount of voltage left in the cells soak it for 24 hours) then discard in the trash.
As Rcadmin stated.. Dont ever poke a hole in them....ever!
Just saltwatered a $70 LiPo pack. Those are hydrogen and oxygen bubbles, BTW. It's a process called electrolysis, I believe. If you catch the bubbles in a tube and hold a lighter under it, it will explode with a large pop as the energy is release to form water once again.
Where you get nitrogen man?
