The 1400 can be purchased at Horizon. No, it doesnt have the BEC style connector. Take Fantomas advice, and buy the switch. The only batter i've seen that comes with a BEC connector is the dynamite. Its not the standard, and its not the biggest battery you can buy either. So when you order the battery, order the switch harness too. You can buy them both at Horizon.
ORIGINAL: Stevied53
i use a 1100 hump pack, 1200 ofna flat pack , and a 1400 flat pack..
Fantomas,
Do you have a link to where you purchased your 1400 mah rx stick pack? Did it have the correct red BEC connector already on it? Does it fit under the LST without a problem? Thanks in advance...
-Stevie D
