RE: Questions about Ziroli DR-I plans???
I found the build straight forward. I built it as per the plans and my balance came out exactly bang on. I powered mine with a Zenoah G-38 and the performance was scale. You should have no problems if you build using the instuctions on the plans. Good Luck, you will not be dissapointed.
Craig.
