RCU Forums - View Single Post - Tissue Covering Help???
Old 09-05-2004 | 07:39 PM
phread59
Default RE: Tissue Covering Help???
Yub, tissue can be a PITA. I would cut pieces that are a little big so you have edges to work with. Then use clear dope around the edges to seal and stick the tissue down. Be sure that you have the tissue stretched tight. Let it dry. Then use more dope to seal and tighten the tissue. You could use a brush to put it on. A little goes a long way so be careful how much you use. If you are using white tissue. You can use coloured dope to shrink with. Be careful at your overlaps to not bunch it up. Doping tissue is an art. Take your time. It will take a few times to get the hang of it. I have been moderately successful with it.
Eyes watering with CA fumes is normal. However it can be a sign of early indications of alergy. I am an ashmatic, been all my life, so I am very sensative to CA. You MUST be aware of your body when using it. Pay attention to how you are breating. Any tightness in your chest or any restrictions in breathing are dead give aways. Sense your skin, especially your face. If your skin gets itchy or feels weird, stop immediatly. If you start to feel the need to sneeze suddenly or your eyes get tight and you are tearing up unusually, stop.
Any change in your bopdy could be an indication of an alergy. I use it sparingly now. Only in applications where I really need it. I also use a ceiling fan above me to blow the fumes away. Try to work away from the fumes as much as posible. Limit your total exposure as much as possible. And just be careful, and you should be fine.
Good luck with your plane. And congratulations on trying something different.
Mark Shuman
