RCU Forums - View Single Post - Avistar question
Old 09-06-2004 | 10:29 AM
britbrat
Default RE: Avistar question
If you are going to do a bolt-on wing hold-down, add a dowel to the leading edge of the wingthat plugs into a hole in your curved block. The block should be re-inforced with 1/8 ply at a minimum. Check out some bolt-on wing mounts at your field, to get a clearer picture.
