RE: TF P-47 completed
Thanks Richard,
I found the Cheveron Perfect Paint very easy to work with. I primed using spray can auto primer. The Cheveron was allied to larger areas using an auto touchup spray gun that holds about 1 cup of paint. This gun runs off a small compressor and tank. I used a Badger 300 airbrush for weathering and panel lines. The final flat coat was also Cheveron. Used Cheveron thinner throughout.
I applied paint as sparingly as possible to keep the weight down.
Paul
