RCU Forums - View Single Post - ball bearing vs bushing servos
Old 09-06-2004 | 09:58 PM
phread59
Default RE: ball bearing vs bushing servos
Yes, you should use a bigger battery! An 800mah at least. 1000mah would be better. The 600's will not have enough juice when you really throw a plane around with that many servo's. It is not worth the risk. As flight time will be severly shortened. And you will be pushing the cells hard. Leading to a premature demize.
Mark Shuman
