RCU Forums - View Single Post - New CA models Epsilon build (easy as pie)
Old 09-06-2004 | 11:30 PM
  #119
Schpankme's Avatar
Schpankme
Default New CA models Epsilon build (easy as pie)
Well Hello AdrianM,
Hypathetically speaking, which of the two meter Pattern planes listed below would you prefer to compete with in Masters/FAI:
Note - both desgins are perfectly balanced and trimmed, with no bad tendencies, having unlimited vertical!
1.) 10lb design swinging a 17 x 12 or 15.75 x 13 (3-blade) prop
2.) 11lb desgin swinging a 22 x 12 prop
_________
Schpankme
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What a Ride!"
