RCU Forums - View Single Post - Water injection!
Old 09-07-2004 | 04:05 PM
Falcon 64's Avatar
Falcon 64
Default Water injection!
Me and a pal is going to do some research about the effect of water injected into a turbine...!
The famous F9F Panther had 60 litres of water for this purpose, and this gave 25-30 % increase of effect.
One liter of water gives 1800 m3 of moist ( like the clouds, not steam).
Only a tiny spray from a OS 10 FSR carburetor will do the job.
Chamberpressure at full speed will be enough to give this fine spray directly into the compressor.
Have to be careful conserning the amount, or the compressor will be damaged..
Imagine what the right amount of water will do tho the pressure wich also lowers the temperature!!
Some experiments is ofcourse nessacery, but we estimate around 30% increase.
Anybody else with some thoughts around this?
I`ll be cack after the first rounds to let you know.
Regards
Gudmund
