RCU Forums - View Single Post -
Thread:
Old 08-02-2002 | 04:52 AM
downunder-RCU
As John says, remove that inner seal but also thoroughly clean out all the pre-packed grease before installing the bearing. That grease isn't designed for the revs our engines run at and the balls could skid which won't do them much good. Personally I'd go for just a shielded bearing (in which case you can leave both shields on). A little oil coming out the front doesn't worry me because then I know the bearing's being lubricated. The flow of oil to the front bearing is controlled by the fit between the front of the crankshaft and the crankcase and usually gives something like .001" clearance. The oil (well, fuel actually) gets forced forwards by the average positive pressure in the crankcase. It seems to me that if you use a sealed bearing, even if only the front seal remains, then it could stop the flow of oil or at least restrict it to the point the bearing doesn't get enough.
