I suspect he is talking about the Cox PT-19 CL Trainer. They are said to be pretty good.
By who?
My experience with it is that it flys like a plastic brick,
if you can get the motor running right.
I would
highly recommend you build a profile style balsa kit. A Cox motor is OK, but the plastic tank and rubber fuel line in the PT-19, as well as the funky way it's all held together make it difficult to run in the PT-19.
My brother and I have taught a lot of kids to fly C/L with a Goldberg Lil'Wizard. A good next step is a Sig Skyray. There are a lot of similar kits still available. They're easy and fun to build, and will fly
way better than plastic. And when you crash them, a little CA and you're back in the air, whereas, I've not yet found a glue that'll stick that flexible plastic PT-19 back together.
Phil
