RE: Is this plane overpowered with a .40?
The only problem you might have is a short landing gear. I would use the ASP .40. As you said, you can always throttle back.
Make sure you aren't using tiny little servos and get the balance correct. You might try an 11-4 prop to start with. More climb, but less speed.
