RCU Forums - View Single Post - tools
Thread: tools
Old 09-08-2004 | 05:33 PM
leftnut
Default RE: tools
a drill for holes in the fire wall , engine mounts, ect...
have to rap tape around smaller bits for horns or smaller screws when using a dremal
asorted drill bits of course..
forget the size of most wing bolt, a tap or dy to make them threads is nice to have
screws drivers for verious screws..horns, servos,ect
an asorted allen drive set metric and standard for wheel collars, engine mount screws
spinners, and etc.
couple of pliers..to bend the control rods or twist on the cleves or get a z bender
a solidering gun have make repairs...mostly the flight box EQ.
them bananaananana jacks always breaks on me.
sometimes you might need to soilder control rods.
a long solid straight edge to makesure the TE of wing gets glue nice and straight.
c-clamps, masking tape, rubber bands, pins...you only have to hands and some building
require more.lol
wieght to wight stuff down
strings..to makesure the wing gets aligned and for pulling servo lines, fuel lines, and ect.
i have 1/4 hooks...i mount it to the center wing , to help me balance the wing of course
a badana..saw dust not too healthy for the lungs.
CA dose this to me..[sm=spinnyeyes.gif]
have sure your work area has good air flow.
a use a piece of glass to cut film on.
a sharp shear helps a lot also
