RCU Forums - View Single Post - MVVS 2.15 carb question
Old 09-08-2004 | 11:22 PM
higheronnitro
Default RE: MVVS 2.15 carb question
Hi Pepsimike
I have an article from the english mag RC Model world that mentions that the spring should not be removed as it will cause the butterfly to wear against the carb throat. I could fax you the info if you would like. I am in the same boat and would like to know if there is an alternative to a herby throttle servo..
