RE: Wildhare 35% Extra 300LX
Hey
You will love the way the plane flies. Very easy to handle. Mine is powered by a BME 110. It has more than plenty of juice to pull it around. It will make gentle landings. I have a trailer so break down of the stab is not necessary for me but it is easy to do. The only thing I would do is buy the heavy duty wing tube from Tom and change the hardware from phillips screws to socket head screws. They are 4mm 7 pitch threads. Go to about 1 1/4 inch long ones. Before you assemble if you go with the BME, it is light and might require nose weight if you want it a little more stable. I am using Hitecs throughout and 1800 mah B&P Batteries for everything 6 volt flight pack and 4.8 on ignition.
Eddie
