RCU Forums - View Single Post - Engine Questions
Old 09-09-2004 | 01:14 PM
leftnut
Default RE: Engine Questions
not sure what you are determinding to be a bad bearing ?
on nitor engines sometimes the engine will not feel like it
rotating smoothly if the crank shaft is not pulled or pressed all
the way forward. generally on TDC or right before or after compression
stroke. if you mount the prop..it'll rotate smooth again.
