RCU Forums - View Single Post - made mistake when taking apart engine
Old 09-10-2004 | 11:00 AM
daven
Default RE: made mistake when taking apart engine
Jim,
You need to rotate the ring so that the gap lines up with a small pin on the piston. Once you have it lined up, you can squeeze the ring and slide it up through the bottom of the sleeve. Its a little tricky, but possible. The next trick is to get the piston con rod on the crank. Take your time, and you will figure it out. Getting the piston on the sleeve is the tough part.
