RE: Semi-Symmetricals
If everything is the same except one plane is a high wing plane and the other is a low wing plane, you would probably not notice much difference in the two. However, rarely, if ever, are all other things the same; go with the high wing plane as your first trainer. It will probably be a bit more stable and easier to learn on than a low wing plane.
