RE: OS160 FX Midrange Problems
Saw this very problem with a 160 at our field. Turned out to be overheating because the engine was tightly cowled. A baffle was installed to direct all the sirflow over the engine and problem disappeared. Try running it with cowl off and see if it changes symptoms any. If it does you will have a clue to the problem.
