RCU Forums - View Single Post - 4-Blade Prop Selection
Old 09-11-2004 | 12:38 AM
ho2zoo
Default RE: 4-Blade Prop Selection
You will probably find that for engines that size (.46 - .91) 3 and 4 blade props are not nearly as efficient as 2 blade. The engine will turn it, but it may not give you the performance you want. But I'm no master on the subject. Experiment with some different props and let us know what you find out. Good luck!
