RCU Forums - View Single Post - Antenna Top or Bottom ???
Old 09-12-2004 | 06:56 AM
DragonHeart
Default Antenna Top or Bottom ???
Hi Guys,
Ok im not exactly a beginner but i know alot of good experience ppl use this forum soo here goes the question............
I kinda had a tree jump out on me and grab my 3D plane, its all ready after a few repairs to go but i done a range test and was about 50-60ft with the ariel on the tx down until i had problems. I then tested another one of my planes and again was the same distance...... i then check the Futaba website and its stated the antenna for the rx should be located at the top of the fuse ?????? and should be 100ft range with ariel down, but most of my planes including these 2 exit from the bottom, very close to the ground........ althou ive never never had any problems in flight with this setup but after reading that its kinda got me thinking so is this just a ground test problem as like i said in flight thier fine ?
Or should i redo them all and exit from the top ???????
Thx in advance for any help........
