RCU Forums - View Single Post - Antenna Top or Bottom ???
Old 09-12-2004 | 10:20 AM
Rodney
Default RE: Antenna Top or Bottom ???
Dragon heart, to be a valid test, you need to have the airplane well above the ground for the test. I'd almost guarantee, that if you set the plane at least 6 foot off the ground on a non conductive surface, you will not be able to detect any difference in range as long as all other elements remain the same.
