RE: OS 46FX Problem!
Also did you recently change your fuel lines around or replace them. I had the identical problem you had a couple years ago. The line coming from the firewall to the carb made a bit of a right angle. Did not look pinched but it was and enough. Ground runs were fine. Engine got lean, hot and quit after a couple minutes of flight. I smply lengthend the lines. Just another thought
