Powerline Cooling Head - Does it work?
Go with Hardcore's Mutant Head. It will drop your running temps considerably. One thing with heads though, be sure you don't run it too lean. What i mean is, although you may be able to lower the temp with a new head, it doesn't mean you can lean it out just because it is running cooler.
