SIG - Still no SU31 wing!!!!
I have the Sig Sukhoi with a BME 50 gas engine and have not had any problems what so ever.
I did not use any of the supplied hardware though and used metal gear servos on all control serfaces. Linkages have NO slop.
I added 1/8" lite ply behind the firewall and glassed the wing joint about 3" to each side of center. I got the control surfaces as close as posible and gap sealed the ailerons.
The plane came in at 15lbs, very light with a gas engine. It is a rocket vertically and the huge cowl slows it dramatically on downlines.
I added 2 degrees right thrust to the engine.
I am prudent with power in level and decending flight.
Joe Brannon
