RCU Forums - View Single Post - Help to fix a problem with a wing.
Old 09-12-2004 | 08:34 PM
fpc777
Default Help to fix a problem with a wing.
I have built a new plane. Sig"s somethin Extra. When the right wing hit the fuselage there is a 1/8 in. gap at the leading edge and tappers to 0 in. 3/4 of the way down the wing. (Screwed that up at the begining)
Two questions :
Is this going to cause the wing to loose that much air flow?
If I put weather striping on the end of the wing to fill the gap will that be a good temporary fix ?[sm=confused.gif]
Thank you for your help in advance
Frank................
