RE: Do I need more right thrust?
From all your posts, I gather you need some left thrust on the engine. Or, mix some right rudder (slave) with the throttle (master). This will cause you to re-trim the rudder to the right for your up lines to straighten them back up........and that right trim will straighten your off throttle lines by pulling them back to the right.
Good luck.........it takes time to get a set-up right.
CJ
