RCU Forums - View Single Post - New Solid State RX switch
Old 09-13-2004 | 01:15 AM
AdrianM
Default New Solid State RX switch
OK, OK its from KO Propo which no one outside of the R/C car guys use but its very cool and KO uses connectors compatible with JR/Air...works with FUT too but it has no ridge on the side..
Its a solid state push on, push off switch with built in battery status LEDs. It is primarily designed for R/C car use where if you smack a wall head on at 50mph or get rear ended/t-boned by a car going 50mph the resulting G-forces can make a conventional RX switch turn off or fail. Vibration is horrendous in R/C cars so living in a plane with a 140DZ or big gas single is a walk in the park.
Its KO p/n: 60224 $35.00
