RE: Expo on Throttle with 8103
What you can do is use mix 1 or 2, set up a throttle to throttle mix, and set points L and H to 0% (so that the mix doesn't affect your travel adjust), and then by using low percentages at points 1, 2, and 3 to adjust the throttle curve. Be sure that you are using low percentages here, if you use too high of a percentage, you could have a spot in the throttle that for instance when throttling up, the throttle increases, then decreases, and then increase again. You can verify correct operation in the servo monitor.
