RE: C-130 updates
Did any of your stabs fit perfect in the saddle?
========That is something that took me a long time to get fit right. When it appreared to be right, it wasn't. I ended up cutting off more of the front of the stab to get it to fit properly. I believe if you set it where you think it should be, you'll end up with negative incicence in the stab. I got pics at home and I'll post one when I get there.
............................... and the rear of the stab hangs over the rear of the saddle. Is this normal?
I think my stab hangs over a little.
And did anybody put ribs in the fuse to support the fiberglass?
-----------I put some reinforcement around the wing saddle area and where the vertical stab meets the fuselage, but other than that, I didn't put any other bulkheads in.
Randy
