RCU Forums - View Single Post - Old chainsaw engine
Old 09-14-2004 | 01:13 AM
Antique's Avatar
Antique
Default RE: Old chainsaw engine
Most gassers run the best at about 28 degrees BEFORE top dead center...You can find TDC by putting something in the spark plug hole to keep the piston from going all the way to the top...Turn the crank clockwise and mark the hub and case at that point..Now rotate the crank the other way and make another mark...TDC is exactly halfway between the two marks...
