ORIGINAL: Tigger N. Bennie
I've read "Deans this, Deans that" numerous times on this forum. However, I think I've only read one time where someone mentioned using an "Ultra Plug" Deans connection with the Mamba. I also set up my recently purchased Triton ($109 less $20 with coupon) with an Ultra Plug off of the banana output connections so there is no adapter used for the 3-cell LiPos. Consequently, I guess someone could simply use a 2 pin micro plug and not think anything of it. Guess what, the charger just finished charging the LiPo. Another successful charge.
I was just wondering, was that cup microwaveable or not?
Pinons? Stock so far. I am working my way around with the M18s though since several shipped with the M18; however, that is only because I drilled two out for my first brushless motor and now I am using the other two for my current brushless motor.
Personally i have run Deans Ultra plugs on ALL my RC items. Whether is 18th scale or 10th scale, I like knowing that i WILL NOT have a bottle neck with my electronics no matter what i throw at it!
The connector on a lipo charger is not that important. Remember..you are only charging the packs @ 1C....so on a 1900mah pack, you are only charging at 1.9A MAX.....so most stock connectors can handle the amps....no an issue.
URC
