RCU Forums - View Single Post - DA-100 ignition help/switch
Old 09-14-2004 | 10:37 PM
coony2787's Avatar
coony2787
My Feedback: (33)
Default RE: DA-100 ignition help/switch
The way i hook it up is .....
The plug with the bare ends has too be either solder or an some type of connector put on it. I prefer just to install a regular battery end on it so that your regulator will plug directly too it.
After you get the plug on plug your regultor in then plug your regulator to a switch. I use a JR charge switch here ( has the charge jack made in it ) Then simply plug your battery in to the switch.
So in reverese order it goes Battery, switch, regulator, ignition box. If you run a 4.8 battery or a 4cell battery you dont need a regulator. If your running lipo's then yes you need the regultor.
I hope this helps.
Chad
