RE: Createx Paint
I am using createx t shirt paints, the only thing I have found that I dont like is it smuges if you dont heat set it with a hair dryer. and thats a little tricky because the heat likes to warp the foam. but I have also found a clear coat by createx so you dont have to heat set and it dosent smuge as bad.
