RCU Forums - View Single Post - crystal question
Old 09-16-2004 | 09:54 AM
Montague
Default RE: crystal question
When range checking, it's also a good idea to check with the engine off, then check again with the engine running. If you notice much of a drop in range, you have some kind of problem that you should fix, like a loose or bad crystal or other issue. Many (most?) people don't do it, but it's a good idea.
