RE: Possible diff case problem?
Just for the record. I took my diffs out to put on the aluminum diff cases. The front top diff case was visibly cracked and split. The rear top diff case was cracked in the exact same spot as the front. It was only visible from the inside and not cracked completely through yet. Glad I got the aluminum ones. Even if they aren't machined.
