RCU Forums - View Single Post - Cannot find: 2.5 (2.4) inch Square PVC pipe
Old 09-17-2004 | 12:34 AM
NightFlight
Default Cannot find: 2.5 (2.4) inch Square PVC pipe
This pipe is used for the fuselage on a Combat Gremlin. I just broke my first and only fuselage. I'm basically poor and looking for a good known source for 2.5" PVC sq. downspout pipe. If I understand it right, it's normally used in the industry to carry water vertically from your roof to the ground. Aparently this pipe used to be commonly available, or so I hear. I've had absolutely no luck. I've tried both hardware and electrical supply stores. Google search results are ambiguous at best.
I found one source, but it was brown and I haven't yet investigated the minimum order quantity. Does anyone know where I can just order a couple lengths of it, say around 20ft total? That should do me for a while. I'm looking to get away with an order for that much material for under $CAN 50 shipped.
Another thing is nylon bolts. It's stupid to pay $1 each from the local hobby supply if I'm going to be breaking them this often.
- NightFlight.
