RCU Forums - View Single Post - Best engine below $200?
Old 09-17-2004 | 08:44 AM
motionmachine
Default RE: Best engine below $200?
The boost nipple under the carb should be plumbed to the nipple located on the backing plate/boost chamber.
I suggest you use a seperate boost bottle for more chamber volume, this also removes unneccessary engine heat from the intake charge.
In simplist terms, a boost bottle/chamber rearranges the existing power over a larger rpm band thus smoothing out the power spikes.
