RE: 91FX Problems
If you cannot get enough fuel flow at full throttle, you'll need to see if you're getting enough pressure to the fuel tank. What exhaust system are you using? Have you tried larger fuel tubing? (Larger tubing will require ties to hold it to the tank and fuel nipples).
Trending lean almost always means a fuel delivery problem. Overheating could be fuel delivery, exhaust system, or cooling airflow.
